Question about LG Computers & Internet
LG 55LW5600 SmartTv 2011 build- the LED screen wont turn on anymore? After hard reset, when turned on, power indicator slow-blinks amber twice, then is steady white. What part likely could be bad?
Screen doesnt light up anymore.
6ya staff
SOURCE:
Rishi Roshan Ali
  • 2427 Answers
SOURCE: black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Posted on Jan 12, 2008
Anonymous
SOURCE: Monitor black screen with blinking amber/green light
You need to reset the display. The display is in a safe mode. Resetting the display is a simple procedure and Planar has the instructions on their website in their online customer support section.
Posted on Feb 26, 2009
ajx13
Arjun Aukta
  • 110 Answers
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Posted on Aug 11, 2009
JOHNJIE
SOURCE: The light on the power switch turns green when the switch is pressed on, but soon after it turns amber and keeps blinking. Therefore there is no display on the monitor screen. The amber light keeps bl
SOLUTION FOR THAT- JUST UNPLUG THE MONITOR AND PLUG IT AGAIN
Posted on Oct 09, 2011
SOURCE: lg tv very slow to turn on
slow turn on's are usually a power supply problem, capacitors in particular. Are you comfortable with opening up the set? If it is under any kind of warranty don't open it, take it back to the place you purchased it.
Posted on Jun 03, 2012
55lw5600 tv has no picture. power red light comes on. led power light on very dim when tyring to turn picture on.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 15, 2016 | LG 55 55LW5600 3D LCD TV
LG symbol on screen flashes on once and red light blinks twice slowly, no sound either. What does 2 blinks indicate ? please advise
Corrupted firmware. A firmware update is necessary. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Sep 21, 2015 | LG Televison & Video
No video no picture, caps look okay, what could be wrong or how to tshoot to determine which PCB is bad etc
Does the screen flash on briefly then go black when first switched on? See my posts in march for my answer to this fault.I traced the same fault on my own tv down to a faulty led in the backlight strip. Also my tv did the same thing,standby light flashed twice and then went out.Hope this helps
Feb 21, 2015 | LG 47LV5500 47-Inch 1080p 120Hz LED TV...
LG 37lc7d wont turn on power button just blinks red and green.
How many times do the power LED blinks at once after switch on. Count it carefully. These blinks are fault indications, which can help you an idea about the faulty internal section circuit. If you wish to get more details about these blinking codes, check this link.
Feb 05, 2013 | LG Televison & Video
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Computer Won't Power Up
If the blinking amber LED is on the computer itself and not the monitor, this is most likely a power supply issue. First thing to try would be replace the power supply. If the blinking led is on the monitor, it probably has bad capacitors and needs to be replaced. (or repaired)
Jul 15, 2008 | Dell Dimension 8400 power supply ** FREE...
Computers & Internet Logo
110 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
