SOURCE: Direct TV Remote Satellite Won't Receive Signal
What is the AUX Fisher brand code for an RCA remote control model# RCR160SBM1
SOURCE: No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
SOURCE: combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
SOURCE: Sansui VRDVD4000
Universal remotes rarely fully work with these type of units. Call Orion customer service 800 289 0980 to price an original remote.
