Tablets & eReaders Logo
Darius Hilson Posted on Sep 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to put microsd card in yuntab 10 inch tablet
tosin_christ
Level 2:
Sergeant:
  • Expert 242 Answers
  • Posted on Oct 02, 2017
tosin_christ
Expert
Level 2:
Sergeant:
Answers
242
Questions
0
Helped
45223
Points
822
First is to check whether your tab has a 'microSD port' or not.
It might not be noticeable when you check on the body/edges/outer frame of your tab otherwise you won't be asking this question.
In this case, you may need to open the back cover of your tab (there has to be say a small part you can readily open to access the microSD port inside your tab).
Where none exists, probably, your tab does not support microSD card insertion.
1 Related Answer
HFCoombs
  • 98 Answers
  • Posted on Dec 28, 2014
SOURCE: why wont my sanei 10 inch quad core tablet read the memory card for my fuji camera? The tablet can recogonize an external card reader but cant read the card in the reader. Do I need a special app?
It may need to be formatted, some cameras do not format the cards properly.
Do u need a SD card before contixp tablet will work
It is for storage and will work without it.
How to Insert and Remove the MicroSD Card from an Android ...
https://www.dummies.com > tablets > how-to-insert-and...
The MicroSD card can be inserted into the tablet whether the device is on or off. Heed these ... to your tablet. The tablet works with or without a MicroSD card installed. ... To use a MicroSD card with a computer, you need an SD card adapter.
Yuntab q88h manual
If the following is not the manual, you may need to contact the manufacturer or a vendor for a manual.
https://fccid.io/2ALZXYUNTAB-H8/User-Manual/User-manual-3438452
YUNTAB H8 MID User Manual Shenzhen Wave Multimedia Co LTD
How do I install a sd card in my hp 10 g2 2301 tablet
Lift the cover on the right side of the tablet.
Insert the microSD card in the lower slot, and press gently on the card until it's firmly seated.
My grandpa bought a RCA for me to put all his songs on it. And they are all on the computer and i dont know how to transfer them
There are two ways:
  • From computer. Use micro USB cable,connect it to tablet. Computer will detect the tablet as storage device. Open explorer. Copy your files from computer to tablet in the folder where you want to store/save.
  • Use micro SD card. Insert microSD card to computer/laptop. Copy your files to microSD card. Remove microSD card. Insert it on your tablet. Access the files. To access files on microSD card, you can see on this video :
Video is courtessy of Youtube - RCA.
You also can use flashdisk as a files transfer storage.
If using flashdisk,transfer procedur is same as for microSD.
If using flashdisk,you need miniUSB to USB adapter. See photo:25848604-tr0bbbe1g5ua2mps4ks3loyz-2-3.jpg
I hope this help.
Regards.
HOW TO INSTALL A SD CARD INTO AN ONIX 7 INCH TABLET
NO NEED to install. Just insert the micro SD card to the card slot. That is it.
When you connect the tablet to your pc, the microSD card will appear as a drive letter on the window explorer. Very easy to use.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
