Computers & Internet Logo
m
murari kumar singh Posted on Oct 02, 2017
On tim LG Disply mod..47LS4500
47LS4500
Grey line down side of screen
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Remote sensor on the tv is not working.Have seen solutions on line that say put headphone jack into the "remote input" or "wired input" port.The 47LS4500 does not have this port. What is the solution?
use a phone camera and look at the front emitter LED the camera will show the invisible output as white light, if you indeed have output showing you can be reasonably sure the remote is working, here is a link for IR sensors on the plus side they all plug into the set with no soldering and just one screw.
IR Sensor Boards MBTV Electronics
Nov 29, 2015 • LG 47LS4500
David terry I have an lg 47ls4500-ud.auszlur tv that has sound but no picture, just a faint blue illumination.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
I am getting no picture on the tv, when I turn the tv on the red standby button shows, and if I change the channel or hit the input button on the remote the standby button flashes 3times and turns off
It sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Vertical stripes
Your LCD panel motherboard has gone dud. You need a new LCD panel...but probably a new tv!
Lg 47ls4500 black screen
If it powers ON, and do not display a screen, check and replace the back light inverter circuit.
Oct 16, 2013 • LG 47LS4500
My freezer mod#ULG80BC-5 every morning the disply
I dont provide refrigerator repair service on commercial units, but my first instinct is to say that E7 is an error code message, likely pertaining to a self diagnostic system, but you would also likely need the manual to determine the source of that error.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
