There are different reasons for this issue. However, there is a great way to solve it. You can resort to this
iPhone transfer software - Leawo iTransfer to sync iPad with your iPhone. Just follow below steps.
1. Run Leawo iTransfer after installing it on your PC, then connect iPhone and iPad to computer with the USB cables. The software will automatically detect the libraries of your iPhone and iPad, show the libraries of your iDevices in the left sidebar. Choose one library and the contents will be displayed in the right part of the window.
2. If you want to transfer all the files in the library from iPhone to iPad, you only need to click the transfer button at the right bottom of the window. If you only want to transfer certain files, you are able to hold "Ctrl" key and choose files, then right-click the selected files and choose "Transfer to > iPad".
3. After choosing files, you will see a pop-up dialog. Click "Transfer to List: iPad" in the dialog and then click "Transfer Now" at the right bottom of the dialog to start syncing iPhone to iPad. You will see "Save to Folder" option below "Transfer to List" option, you are allowed to transfer files from iPhone to computer by checking this option.
4. The software will start syncing iPhone to iPad after you click the "Transfer Now" button. The progress bar in the dialog will show the percentage of the process, and when the process is done, you will find the files in your iPad. You are able to check them in your iPad, or in the iPad library within the software.
For more details, check:
How to Sync iPhone to iPad
