Televison & Video Logo
R
Richard John Price Posted on Oct 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get a manual from for the Bush DVRHS02 ?
Terry
Level 3:
  • Bush Master 11,377 Answers
  • Posted on Oct 14, 2018
Terry
Bush Master
Level 3:
Answers
11377
Questions
Helped
4625124
Points
152765
2 Related Answers
Anonymous
  • Posted on Aug 30, 2011
SOURCE: Bush Video Dvd combo Dvrhs02 Lock Code
cant get child lock off
gopakumarg43
  • 76851 Answers
  • Posted on Sep 01, 2017
SOURCE: hi, what are the universal remote control code/s for a BUSH DVRHS02 DVD Recorder & VHS VCR Recorder Combination please ?
0218,0032,0290 Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Testimonial: "The Knight, thanks for the info, but none of those codes work. Every code list I have looked at before I posted here doesn't have Bush DVD/VCR Combo either."
Hi, what are the universal remote control code/s for a BUSH DVRHS02 DVD Recorder & VHS VCR Recorder Combination please ?
Programming Notes
User manualfor bush dvrhs02
Here is a link to get a dvhrso2, don't know if this is the one you need or not?
http://3wires.net/manuals/BushHVRS02.pdf
I have just bought a second hands bush AG66TW gas cooker. Unfortunately I haven't got a manual for this. Could you please let me know where I can get this. Thank you
[PDF]bush cooker manual.pdf - WordPress.com
https://tisinglowthpho.files.wordpress.com/2015/.../bush-cooker-manual....
Bush Cooker Manual manual for bush ag66tw gas cooker. Asked by dougie on 03/15/2015 0 Answer. ManualsOnline posted an answer 5 months, 4 weeks ago.
Is there a Unlock code for bush btvd91216w
This is everything that I have:
Try this general bush unlock:
Press Open tray
Press 2, 8, 1, 2 and Enter to get to the manufacturers settings
Select the required region, by pressing Enter on 9 for multi region
Press Close tray
If that didn't work, try this:
Try this one:
1. Press the Open button on your remote control to open the drive tray
2. Press the 9 button on your remote control
3. Press the 7 button on your remote control
4. Press the 3 button on your remote control
5. Press the 5 button on your remote control
6. Using the on screen menu, highlight the region option
7. Press the Right button on your remote control
8. Using your remote control, select 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
9. Press the Enter button on your remote control
10. Press the Open button on your remote control to close the drive tray
Then there is the following and good luck:
Bush 1000
  1. Open the tray
  2. Insert a disc with desired region code, but do not close the disc tray
  3. Press 0, 1, 2, 3, Play
Bush 1005 / 2004A / DVDAV7
  1. Press the OPEN/CLOSE on the remote
  2. Press 3, 3, 0, 8, 8
  3. Press the button for the desired region or 0 for multi-region
  4. Press OPEN/CLOSE
  5. The on-screen display will now indicate the currently selected region
Bush 2000
  1. Open the disc tray
  2. Insert RC-1 DVD, don't close the disc tray
  3. Press 0, 1, 2, 3
  4. Press PLAY
    To activate RC 2:
  2. Insert RC-2 DVD, don't close the disc tray
  3. Press RETURN and PLAY
Bush 2002 / 2004
  1. Press OPEN
  2. Press 7, ENTER, 7
    A menu should appear (codefree=13)
    Method 2:
  1. Press OPEN
  2. Press 2, 0, 0, 1
Bush 2005 / 2008 / 2009
  1. Turn on the player
  2. Press OPEN/CLOSE
  3. Press ZOOM
  4. Press A/B
  5. Press Up, Left, Down, Right
    A note should be displayed.
  6. Turn it off
  7. Turn it on
Bush 2023 / 2024 / 2523
  1. Press OPEN
  2. Press 2, 8, 1, 2, Enter
  3. Set the country code to 13 and press Close
Bush 2028
    already region free
Bush 2039
  1. Press OPEN
  2. Press PROG
  3. Press ENTER three times
  4. Use UP/DOWN to select region
  5. Press STOP several times to set the region
Bush 2047
  1. Press OPEN, SETUP
  2. Go to "Preferences"
  3. Enter 2, 8, 1, 2
  4. Use UP/DOWN keys to select the region
  5. Press SETUP, OPEN
Bush DVD-102
  1. Press OPEN/CLOSE
  2. Press 2, 0, 0, 1
  3. Press ENTER
  4. Select RC (codefree=13). You can disable MacroVision, too.
  5. Press OPEN/CLOSE
Bush DVD-142TV
  1. Press DVD function on your TV set
  2. Press DVD Setup on the remote
  3. Press 1, 3, 6, 9
  4. Press Left three times
  5. Press RIGHT once
  6. Select VERSION
  7. Change the region code
Bush DVD-143TV
  1. Press DVD/TV, DVD
  2. Open the tray
  3. Press SETUP, Right, Left, Down, Up, Display
  4. Enter 0 (or 1-6 for other RC)
  5. Press Enter
    VCD/SVCD playback
  1. Press SETUP on remote
  2. Press Next, Prev, Next, Prev
    Ver should appear in the top right
  3. Change 3001 to 3000
  4. Change 5001 to 5000
Bush DVDAV11K
  1. Open the tray (be sure to be in stop mode)
  2. Press SETUP, Next, Prev, Next, Prev
  3. Select 255 for region free (use LEFT/RIGHT)
  4. Press SETUP
Bush DVDR3000
  1. The disc tray has to be empty
  2. Press TV/DVDR
  3. Press RETURN, DISPLAY
  4. Enter 8, 8, 8, 0
Bush DVHS1
  1. Press the DVD button on the remote
  2. Press OPEN
  3. Press 0, 5, 2, 0
  4. Press UP, DOWN, LEFT, RIGHT
  5. Change the region (0 = multi-region)
Bush DVRHS02
  1. Push SETUP button on the remote
  2. Select SYSTEM INFO on the menu
  3. Enter 1, 1, 0, 1
  4. It shows the current region code
  5. Push 0 on the remote for region free
Bush 2001 / 2020 / 2026 / 2029 / 2035XI / 2038 / 2042 / 5020 / BTV213DVD / DVR3000 / DVRS01 / PDVD0707 no known hacks
5answers
Turn the unit on then press the 'vcr/dvd' and 'disc menu' buttons on the unit together and hold down until the unit reboots
2answers
Top Bush Televison & Video Experts
matt martin
matt martin
Sean Wright
Sean Wright
john h
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
