SOURCE: philips 37pf9631d/37
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick
motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that
would help a lot, I can send it to anyone who wants it via email/gmail.
Let me know if anyone want one.
I also heard that this problem appeared with some people because the of
the burnt fuse in the TV. To fix that it has to be taken to the tech
shop.
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
SOURCE: philips 37 flat screen
I'VE WORKED ON A LOT OF PHILIPS FLAT SCREENS AND ALWAYS NOTE ,WHEN THERE ARE PROBLEMS WITH THESE SETS--THE RED LED WILL BLINK GIVEN YOU A CODE FOR TROUBLESHOOTING..EXAMPLE---ONE L0NG BLINK,4 QUICK BLINKS--BAD AUDIO BOARD,,,SOOOOOOOOOOO,CHECK YOUR BLINKS,HA!
SOURCE: philips TV won't turn on
There is no quick Fixya to this problem, As a repair tech I understand but your PSU power supply unit overheated causing you logic board to give you this flashing red light, I cannot help you 1,500 miles away and would like a good rating for the information though, phillips has so many autherized repair centers that I would call if I where you, this can be fixed for under $100 bucks phillips manavox psu boards are cheap and the labor will dpend on where you live, if this information find helpful to you please rate accordenly thank you and good luck!!
Btw, Iām available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
