Have you tried to switch source or imput
Testimonial: "Tried both, only get sound"
Tried both only get sound
try using a different cable. you might have a bad hdmi cable that has burned out.
did you hard reset. unplug tv and let stand for 15 minutes and then replug in. after that is the CEC turned on.
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: 47' (sic) LED TV, model number m470vse. Why doesn't the backlight work?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
SOURCE: How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
have a look round this site.very good guides.hope it helps...
SOURCE: When testin a power supply or led board on tv do i test dc or ac with multimeter?
Your power supply board is working if you get audio and imgaes.
You test AC only the AC side of the transformer before the Rectifier Diodes. Everything after the Diodes will be in DC.
did you get to see any spec of backlight as shown in
LCD LED TV Repair No Image Blank Black Screen Flashlight Test How to Fix...
