SOURCE: can't get picture
Hello matthew95765,
The TV is working, the message is coming from the dish box. What you need to do is to determine if the dish box is connected to the dish and that it has signal at the box, because the message it is delivering to the TV is that it is not receiving signal from the satellite. so you have to check the connection at the satellite and at the box because those are the only point that can generate the error you are getting.
I hope this helps,
Thank you,
Shuttle83
SOURCE: SATELLITE DISH
Sure you can, if you have Dish Network go to the receiver and turn the TV and receiver on. Then press menu-6-1-1. This takes you to the point dish screen. You will come out with better results using a compass to find the azimuth the dish should be pointed toward and bore sighting the dish by pointing it in that direction. You then will need to move the dish in very minute increments pausing for 15 to 20 seconds after each move to ensure the satellite signal can be found. If you have ran a check switch prior to this and have lost all satellites you more than likely will not receive a signal until you run another check switch and have found the signal of at least one of the orbitals. If this proves to be to tedious and many times it will you can usually find an inexpensive signal pointing device at a store like Radio Shack. Hope this is some assistance to you. Let me know if I can be of additional assistance and thank you for using Fix Ya.
SOURCE: No picture on dish tv
The 311 receiver is normall a pretty tough machine. Getting a 70 % signal is normal, and it shouldn't fluctuate too much unless you have something like a tree or other obstacle in the way.
85% of the problems with these older systems is the LNB. I see it all the time.
My first suggestion would be changing the LNB (the eye of the dish). You say that your system is 10 years old, and there are a lot of LNB's out there that go bad over time. It may say that you are getting signal, but the quality may be so poor that the receiver may not know what to do with it.
If you have 2 LNB's (separate eyes) on your dish, then you have two singles or duals with a switch 21. I'd remove these and replace them with a Legacy Twin LNB. If you have a Twin LNB, then replace it with another Twin (especially if it has "lot" number printer in the front of it, these are notoriously bad).
I hope this helps you...
SOURCE: Lenovo T60 interfacing with Vizio HDTV using RGB cable
SN:V6-72866 a 3rd of screen is blairing and turning white
