Description
Intermittent C-0201 (C0201), C-0202 (C0202) and C-0203 (C0203)paper lift error codes.
Solution
PROBABLE CAUSES:
1.The trail edge paper guide (p/n A03U R756 00) may not be pressed against the paper. This will allow the paper to fall backwards and induce the error code.
Instruct the end user to check the position of the trail edge paper guide whenever paper is loaded into the paper tray.
2. Coupling for the tray lift for Tray 1, Tray 2 or Tray 3 is obstructed or out of alignment causing the tray to not lift.
Inspect the coupler in the back of the machine for paper preventing the pin from seating in the coupler. Check alignment when tray is inserted. If out of
alignment try to adjust the drive to properly align.
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: minolta bizhub erorr codeco202
CO202 relates to tray 1 (top tray). It hasn't managed to lift the paper successfully.
Open the tray, remove the paper, reset the machine (open/shut front door) then reload the paper and try again
Hope that helps
Regards
Taminol
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
SOURCE: Konica Minolta Bizhub c350 error code c-0510
I have this code
C0510 Upper fusing roller abnormally low temp
how can I replace the thermistor in the fuser
