1.Mark position and length of buttonhole on fabric.
2.Set button on the base and slide base forward to secure button.
* If button does not fit on the base, adjust slide on base to diameter of button plus thickness of button.
a= Length of button + thickness
3.Pass upper thread through the hole of buttonhole foot and attach buttonhole foot to machine.
Bring upper and bobbin threads to the left under foot.
4.Position fabric under presser foot so that the center line mark is in the center of the needle opening in the buttonhole foot. With the main part of the foot pushed to the back, lower the presser foot lever.
5.Lower the buttonhole foot lever so it is positioned behind the raised finger on the foot (see step 5 illustration). a
Note:Machine will not start to sew if buttonhole lever is not lowered properly or buttonhole foot is not positioned correctly.
Note:If machine does not reset for second buttonhole, be sure the presser foot raised finger is pressed against the lever.
6.Hold upper thread lightly and start the machine.
Ref. :babylock.com/downloads/manuals/
SOURCE: BUTTONHOLES
Yes, If you have a zigzag function use that. First you must keep the zigzag function stationary then set it to about a one or two on the stitch dial. Try that!
SOURCE: I need to know how to thread a babylock companion
http://www.sewingmanuals.com/
also you might be able to find a tutorial in you tube
SOURCE: How to make buttonholes on a babylock 1170 machine
babylock does have some manuals
contact their customer service & they can tell you where to look for a manual.
or try sewingpartsonline.com
SOURCE: where does the tension spri ng go on my babylock 1550 bobbin winder
It may be worthwhile to purchase a new bobbin case for your machine. Trying to re-attach the spring will most likely cause the spring tension to change making it difficult to get the tension correct. Bobbin cases do wear out and really are not all that expensive to purchase. A lot of sewists keep more than one bobbin case on hand so they can adjust a specific case to accommodate the tension for specific thread weights.
