Question about Sennheiser Audio Players & Recorders
I am not getting any sound from my Sennheiser HDR 110 headphones. Green light is on at the Transmitter and new batteries installed in headset?
6ya staff
SOURCE:
Anonymous
  • 9 Answers
SOURCE: Bad battery for my Sennheiser HDR 45 headphone
A replacement battery can be purchased from Sennheiser for $20.00.
Battery is: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
Posted on Jan 15, 2009
Anonymous
  • 9 Answers
SOURCE: Bad battery
Battery Part Number: BA 151
Sennheiser Link:
Anonymous
SOURCE: sennheiser hdr 30 battery
you can check in ebay battery # ba151
Posted on Feb 17, 2009
Anonymous
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
Anonymous
SOURCE: sennheiser hdr 120 headphones no longer hold a
Twist the pad counterclockwise on the left earpice. You'll find the batteries underneath.
Posted on Mar 06, 2010
Sennheiser HDR120 - missing transmitter / alternative OR replacement?
The system is working in the 860 Mhz range, so not that common. Most of the time it is cheaper to by a complete new system then to tray to buy components. Just keep looking in the thrift stores you find a transmitter for this headphone for a good price.
Jun 15, 2014 | Sennheiser HDR 130 Consumer Headphones
Sennheiser 120 green light goes off
Can you remove the rechargible batteries ? To try and reset them ? Or maybe replace them ? It sounds like the batteries have gone bad and not charging
Nov 12, 2017 | Sennheiser HDR 120 Consumer Headphones
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
Feb 09, 2012 | Sennheiser HDR 130 Consumer Headphones
I have a huge problem with these headphones (the Sennheiser HDR 120)... and my wife bought two of them... They have great sound on the computer, but once the green light turns off on the base? There...
The volume of the sound source (Mac) must be sufficient, otherwise the transmitter automatically turns off. Turn up the volume on the Mac, and turn down the volume on the headphones. There is no way to disable the Automatic On/Off function of the transmitter.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Aug 12, 2011 | Sennheiser RS 120 Consumer Headphones
My sennheiser hdr 130 has no sound even though it has lights on its based and it is connected to my t.v. what is the cause of this problem and the solution?
This worked for me (this solution was posted on another thread). Unplug the base and take out the headset batteries. Wait 30 seconds. Reconnect. Turn on head set. I could hear immediately!
Jun 13, 2010 | Sennheiser HDR 130 Consumer Headphones
Sennheiser hdr 120 headphones no longer hold a charge. where are the batteries in the headset?
Dec 27, 2009 | Sennheiser HDR 120 Consumer Headphones
No sound thru my Sennheiser RS 110 headphones!
check with the manufacturer's website . Perhaps they have technical support
Jun 01, 2009 | Sennheiser RS 110 Consumer Headphones
Loud hum in Sennheiser HDR 6-9 headphones.
It's been a while since you posted this, Were you able to get the problem solved? If you are in the NY metro area, I have an extra T6-9 and I could test to verify if the proble is with the headset or the Freesound unit.
Mar 23, 2009 | Sennheiser Audio Players & Recorders
No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Mar 03, 2009 | Sennheiser HDR 140 Consumer Headphones
Battery is: BA 151
Sennheiser Link:
Dec 24, 2008 | Sennheiser HDR-45 Consumer Headphones
283 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
