SOURCE: Pull cord on chain saw will not retract.
Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
SOURCE: Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
SOURCE: how do i replace the pull cord on my stihl cut off saw
it is gonna take some time,take all screws off housing,pull casing off,be careful with the rewind spring and be sure you have spring wound-up for re-install.
SOURCE: Ryobi 40cc chain saw, pull cord won't turn rotar assembly
I had the same problem with my 18 inch Ryobi saw. The problem is the tabs that engage the recoil to the flywheel are of poor quality steel and they bend out of position. The end result is when you pull tyhe rope it just jumps and wont start. Eaven the new parts do the same thing. Simple soultion is remove the recoil starter four screws require a torx bit or a flat screwdriver. after your remove the recoil starter using a pair of pliers bend the two tabs upwards untill they are not quite straight up (about a 80 degree angle be carefull not ot brake the tab off) once you have done this remove the center nut that holds the flywheel on. the silver pins that hold the tabs in position need to be punched out but remember how they go back by doing only one at a time and remember how the spring is installed. Turn the flywheel over and using a punch and hammer remove the pins. Put the tabs in a vise to hold them sucerly clean the steel as best you can on the inside of the bend. Fill the bend with brazing rod or coat hanger if you haven't got any brazing rod avilable. You don't have to com;leatly fill the bend but put enough in there to suport the tabas so they can't bend agin. Reassemble the saw and you're done. Mine works great now, better than new. This problem isn't limited to recon saws only, mine is a new saw and I still had the problem. Good luck herbdogs
SOURCE: I tried to start my older Poulan Chain saw a day
Did you remember to mix oil with the fuel before you put in the tank?
Remove the spark plug wire and the spark plug. Remove the muffler. Shine a light through the spark plug hole and inspect the cylinder through the hole where the muffler was. Is it smooth and shiny? Use the starter to move the piston up and down slowly. Is it smooth or does it appear scratched and gouged?
I suspect parts of your piston are adhered to the cylinder wall. If that is true it will probably cost more to repair it than to replace it.
You needn't take it to a poulan repair center. Most Stihl outlets employ good mechanics and can repair any saw. HTH
Lou
Shh... my Husqvarna gets serviced by a Stihl dealer... The Husqvarna dealer is actually closer to me. I feel better about the Stihl mechs.
Testimonial: "Very helpful"
check your valve gap.
