2 2/3
An improper fraction is simply a fraction with the numerator being larger than the denominator.
To make it an improper fraction from the mixed number given, just multiply the whole number (2) by the denominator (3), then add the numerator (2). The result is the new numerator and the denominator remains the same.
In this case (2 2/3), it would be 2 * 3 + 2 for the numerator....or 8. So 8/3 would be the improper fraction.
SOURCE: Does the TI-86 simplify improper fractions into mixed numbers?
for my 82 i put my fraction in parentheses then press MATH and scroll to >FRAC
SOURCE: how to 6 2/5 as a improper fraction
multiply the 6 by the denominator which is 5 and then add it to the numerator which is 2 so your solution is 32/5.
SOURCE: need to know how to 6 2/5 into a improper fraction
The Improper fraction of 6 2/5 is 32/5. I would like to know or clarify the concern about the 30x?
SOURCE: how can i change a mixed fraction to a improper fraction ?
Multiply the integer portion by the denominator of the fraction, add the numerator of the fraction, and put the result over the denominator.
If you're asking how to do this automatically on some calculator, what make and model?
SOURCE: How do I change a improper fraction to a proper fraction
Improper Fractions are where the numerator is greater than (or equal to) the denominator - 6/4, 9/2, 6/6. Here the top number is divided by the bottom number and the remainder left on top of the bottom number, so 6/4 = 1and 2/4 = 1and1/4 (Should be written together without the "and" Can't do it on this site as it looks like12/4 and 11/4).
9/2 = 4and1/2
6/6 = 1
Proper Fractions are where the numerator isless than the denominator - 1/3, 4/5 etc.
