SOURCE: can not reboot
Try tapping F8 at start up and try booting in safe mode...If this fails you will need to reinstall your OS.
SOURCE: computer beeping and saying reboot and select proper boot device
When you reboot, go to BIOS, restore factory BIOS settings. If that doesn't help, you'll need to reinstall your OS.
SOURCE: reboot and select proper boot device or insert boot media
This error is informing you that you don't have to proper booting device selected in the bios ( basic input/output system).
It is either pointed to a CD or DVD drive and not the hard drive if installed.
You may have lost the hard drive boot sector.
Usually at start up the screen will give the choice what boot device you want to start your operating system with that is the hard drive or the CD or DVD.
SOURCE: On my asus eee pc
It sounds like you have a bad hard drive. Make sure you don't have any CD/DVDs in the drive if that model has one and you don't have any USB devices plugged in at boot.
SOURCE: my hp mini is showing
Insert a Bootable Opearating system CD
Reload Your Operating System if Problem persist change your hard disk
Load the Operating System
