SOURCE: problems transfering apps from iphone to Ipade
You are able to use any appstore app with the iPad. Make sure your iPad is listed as a connected device in the left side bar of iTunes. Check your sync settings to make sure they're set to sync with your iPad and if needed restore your iPad using the restore button and try to sync again.
To make an application fullscreeen tap the small "2x" button in the bottom corner of your iPad. This will upscale the app to fullscreen.
Hope this helps, if you found this helpful please leave some feedback. Thanks.
SOURCE: 3g not working on apple Ipad
As far as I understand it the ipads that have just been released are wifi only. 3g are available from late April, see the www.apple.com for details.
SOURCE: Apple Ipad screen isn't working
If the issue persists after a restart, there may be an issue with your digitizer / touch panel. Apple willhelp you with this because it is so new. However if you dropped it in water (etc.) and if apple doesn't replace it for you, You can get the digitizer at iPad Repair and there is a guide that shows you how to put in the part at Electronics Repair Guide.
Testimonial: "thanks"
SOURCE: The PC on which I had itunes that synced with my
You can use iPad to PC Transfer, which can help you transfer from iPad to PC. iPad to PC Transfer is a professional sofeware, which can help you transfer Music, Movie, Photo, ePub, PDF, Audiobook, Podcast and TV Show from iPad to PC or iTunes library.
SOURCE: transfere photo from laptop to apple ipad
To transfer photo from laptop to iPad, follow this steps.
1. In the iPad management screen, click the "Photos" tab at the top.
2. Check the "Sync Photos" box at the top.
3. From the drop-down menu next to that, select the program or folder that contains your photo library.
4. Once all your settings are correct, click the "Apply" button at the bottom right corner of the iTunes window to sync again and add photos to your iPad.
5. Photos will consume space on your iPad, so keep that in mind as you select between syncing all photos and individual albums and videos.
