SOURCE: maytag electric dryer. Tumbler won't turn.
The first thing to check is the drive belt. you will need to turn the dryer on its side and look to see if the drive belt is broken. If this is o.k it will be the motor.
SOURCE: my AMANA electric drier will not heat
Verify 220 volts to the terminal block where the cord connects.
If 220 is there, unplug the dryer and check the thermal fuse and hi-limit thermostats on the dryer cannister.
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
SOURCE: i have a model DE303 series 07 maytag electric
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
SOURCE: Maytag Performa electric dryer MDE2300AYW won't heat
If it isn't producing any heat at all then the element is more than likely burned out. It's a pretty routine situation and you can probably fix it yourself if you have any experience with tools. Once you take the back off of the dryer it becomes somewhat self explanatory. Unplug it first! If you don't do that kind of thing then there's still no worries. Appliance repair centers do this job every day and it's usually pretty reasonable and doesn't take more than an hour once they get around to it. I'd predict a bill in the $50-60 ballpark. ANY service center can do this little job as well as any other so find the cheapest one. You should be able to get an estimate (if not exact price) over the phone.
