Question about Sony Bravia KDL-32XBR9 32 in. LCD HDTV
Sony BRavia Screen moves up and down when a dvd is inserted
I have a sony bravia 32" tv and a panasonic 5 dvd disc home theatre system attached. There are a lot of dvd's in my house that when put on in this system with my tv screen moves up and down and when played on other TV's in house it works perfect. Apart from the DVD's TV works perfectly fine and again the DVD's I order from netflix work perfectly fine.
6ya staff
SOURCE:
Jaime Hernandez
  • 2337 Answers
SOURCE: Instruction Manual for Sony BRAVIA KDL 32 P 3000
You will find the user guides in different languages by clicking here.
Posted on May 20, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
Posted on May 18, 2009
mahesh patel
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
bob_computer
Project NOMAD
  • 3153 Answers
SOURCE: Airsoft gun hit Sony Bravia LCD screen, can this be repaired??
Yes but not cheaply
Posted on Aug 10, 2009
Paul Hutchinson
  • 909 Answers
SOURCE: installing sony dvd home theatre dvd recorder to digital tv
you may have to press the audio button or set the audio stream on the dvd's (disc) menu, as some films use the 2 channel audio as default
Posted on Jan 02, 2010
Why nosound on sony 40cx520thru home theater
Check your TV Menu Sound output settings, Check your interconnecting audio cable and check that you have inserted the cable in the correct out/inputs on both items.
Jul 31, 2014 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Does this model have Bravia sync?
Yes it does per SONY web site:
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&productId=8198552921665164630&langId=-1#specifications
BRAVIA® Theatre Sync™ technology
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
Feb 02, 2011 | Sony BRAVIA KDL-40V3000 Television
How to connect 5.1 home theatre to sony bravia lcd tv
how to connect philips home theatre dsp 2500 to sony bravia
Jun 07, 2010 | Altec Lansing VS3251 Speaker
I have a sony bravia davhdx274 but i no longer
Yes, but you will have very limited control for internal adjustments.
You can purchase a new remote from www.remotes.com
or 1-(800)REMOTES and they will ship it to you within 5 days.
Good Luck !
Feb 09, 2010 | Sony BRAVIA DAVHDX275 Theater System
Installing sony dvd home theatre dvd recorder to digital tv
Jan 02, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
How to connect Panasonic DMR-EZ25EB to KEF KIT 120
OK for some odd reason I never noticed that this was a reghurgitated question
BUT hey
The only way to really do what you want is to insert an AUTO HDMI switch to the AV1 and go from there.
http://www.monoprice.com/products/subdepartment.asp?c_id=101&cp_id=10110
Have a selection
Oct 06, 2009 | KEF Audio KIT120 Theater System
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Sony Bravia KDL-32XBR9 32 in. LCD HDTV Logo
115 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
