Hello. I just purchased the Nikon Coolpix S200. I took pictures today with it and found that when I use natural light the picture turns out really grainy (I guess that's called noise?) and when I used the flash the pictures turned out fine. I hate using the flash and love using nat light. Is there something I can do to prevent this from happening? Or is there someway to edit the grainy pictures in the camera? Thank you.
SOURCE: very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
SOURCE: Blurry images on a Coolpix 5700?
This camera was in the time when the ccd had problems.
http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html
Call Nikon concerning your camera. You can send it to them, they will estimate it, and may repair it for free if it is the ccd problem.
SOURCE: Grainy screen
Check the iso settring, if it's too high you'll get a grainy picture. Also, it's worth selecting reset in the camera menu to get the camera b ack to factory reset values.
SOURCE: Some of my pics are grainy
lower the ISO settings to 200 or 400 specially if you are shooting in daylight.
SOURCE: fuzzy grainy screen on nikon coolpix camera
Did you see if it is in manual focus mode? Try to switch to auto in the menu, or do a complete reset in the menu. Who knows what the last person was doing when you last used it, hehe
