The airline broke our front wheel, pulling the wheel apart at the swivel pillar. I have two pieces instead of one. One piece is the plastic neck which attaches to the stroller frame, and the other piece is the wheel with the exposed swivel pillar. Any tips on how to get these pack together? It looks as though it needs to be taken apart somehow then reassembled.
SOURCE: Stroller Wheel Broke
replacement parts
LINK: http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
Telephone
Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Postal Address
Graco Children's Products Inc.
Attn: Graco Store Consumer Services
150 Oaklands Boulevard
Exton, PA 19341
SOURCE: GRACO STROLLER FRONT WHEEL BROKEN
you can get the wheel here
http://www.amazon.com/Graco-Quattro-Deluxe-Stroller-Renaissance/dp/B000CEXO0C
Contact Graco directly...the will send out a free replacement wheel. The whole unit comes together and snaps on.
SOURCE: 2000 dodge intrepid driver door latch broken
We purchased a door latch to replace ours from Dodge. It came with instructions as follows:
Instruction Sheet
Front Door Handle/Bezel Replacement for LH
1. Remove the front door trim panel using the procedures outlined in Section 23 of the appropriate service manual.
2. Place door trim panel on a clean work surface. Drill the mounting bosses' heat stakes, which attach the existing door handle/bezel to the panel, with a 21/64-drill bit. Take extra care to only drill in the center of each heat stake.
3. Remove existing handle/bezel from trim panel.
4. Clean the back of the trim panel of plastic fillings.
5. Seat the new handle/bezel into location.
6. Place the push nuts onto the handle/bezel bosses.
7. Use a 10 mm socket to install the push nuts all the way down on the mounting bosses to secure the handle/bezel onto the door trim panel. Using a wiggling side-to-side motion may be helpful.
8. Install the lock switch from the original handle/bezel to the new door handle/bezel.
9. Reinstall the door trim panel using the procedures outlined in Section 23 of the appropriate service manual.
Hope this helps.
SOURCE: im looking for replacement plastic swivel part. left side
Try asking here:https://servicesales.sel.sony.com/ecom/accessories/web/welcome.jsp
