SOURCE: Westinghouse LTV 19w3 shuts off
The same thing was happening to mine and the problem was in the power supply. Apparently, there was a loose connection causing it to go in and out. The round connector end that plugs into the monitor has two prongs on the inside. I was able to bend each prong toward the center with a thumb tack so that it would have a tighter connection, and it now works fine. Unplug from wall before working on the prongs.
SOURCE: I need an AC adapter for my Westinghouse LTV-19w3
i can get a power supply for 45.00 . it will work. when you get it , whenever you turn off your LTV193W, unplug the power supply . the box will get hot even with the television off. let me know if you want one. thanks.
[email protected]
SOURCE: Westinghouse LTV-19w3: Blue power light is on in
My TV is doing the exact same thing... were you able to find a solution? If so could you let me know?
Thanks
Mark
SOURCE: looking for a power cord for LTV-19w3,how do I get
try ebay if you search for your model number on there you should be able to find it
