You can get one online for only a few bucks...look at the male plug on the set, there are 3 kinds of plugs used, one is like a computer monitor 3 prong plug, another is a 2 prong round on one side and square on the other and the 3rd is a 3 prong but its rounded on the ends, unfortunatly there are a few models that use a transformer hopefully yours isn't one like that...here is the most common one in Westinghouse....https://www.ebay.com/itm/AC-Power-Cord-Cable-for-Westinghouse-LCD-TV-10-Feet-10Ft-Extra-Long-/172208931835?epid=1970030091&hash=item281873c3fb:g:wb4AAOSwIzNXOfJD
SOURCE: unable to program cable channels on westinghouse lcd tv
There is some system reset to set the tv back to default settings. Also some boxes are picky and want the tv to be on chanel3 or 4 for the scan.
SOURCE: Lost mains power cable for Beko 20LB450 Lcd Tv 50 CM
It's universal unless it's also an 12V set.
Make a picture of the power connector with a mobile telephone and go to your local electronic store.
SOURCE: westinghouse LCD power light but wont turn on
G'Day!
Unfortunately, what you're describing is a repair
issue. You won't be able to address the problem with troubleshooting.
There is a part inside the TV that needs to be replaced. Since you're not under
warranty the cost will likely be a minimum of $200 parts and labor.
However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
SOURCE: westinghouse 32" lcd tv model # sk-19h210s won't turn on
Try unplugging it . Wait a few seconds and plug it in again.
