Try this site for help it is one use manual site.
https://www.ufpi.com/~/media/files/literature/product%20literature/wirelesssmartdoorbellkitusecare.pdf
or thry this one if it has camera abilitys?
https://www.homedepot.com/catalog/pdfimages/d0/d0f2c191-1f45-4694-960a-2740fd012f5b.pdf
good luck.
SOURCE: I have Heath/Zenith wireless doorbell.
"sometimes out the blue it will chime"
if for example the doorbell runs on 2.4Ghz signal and then you have a wireless phone which is also on the same frequency, everytime you use the phone the doorbell will ring. got it?
SOURCE: my pushbutton doorbell activates my neighbor's chime
in the chime box and remote you can change the setting for the remote signal that is picked up( refer to your manual for the correct settings) these will be a set of pin connections in the chime box and in the remote switch that will have to be set to another selection
SOURCE: my doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
SOURCE: New wired Heath/Zenith doorbell buzzes until disconnected
it sounds like you have a bad push button . if the wires where crossed you would most likely have this problem as soon as you turned on power .
SOURCE: How can I change the frequency on my wireless
Not sure of this model so suggest you give them a call on
01925 712000
