Does not appear to want to connect to my wireless system.
Not sure if this will help you out,but if not go to this link...
Press the button on the remote control to access the home menu. Use the cursor buttons to select SETUP and press the 'OK' button to confirm. Select CONNECT TO NETWORK and press the 'OK' button. Check whether your router supports Wi-Fi Protected Setup (WPS).
47PFL7666H/12 Philips 7000 series Smart LED TV 47PFL7666H 119 ...
www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=47PFL7666H/12...
set up my new Phillips TV Google Search
SOURCE: Dell inspiron 1505 not supported wireless adapter in the system
Check Control Panel - System - Hardware to see if you have a wireless card listed under Network Adaptor.
Click on it to see if the driver is installed ok.
Does the laptop have a switch or function key to enable the wireless?
