Your windows XP is pirated and that is why the Microsoft popping up on the screen to activate. It will be remove unless you reformat again your windows system. Then after you reformat disable the windows update for not again be activated by Microsoft.
OK, go to run command then type MSCONFIG then enter and select STARTUP, find the icon which is currently use for activating windows. If your using a Genuine Microsoft and do not again because you already have it. It tells that your going to activate because you didn't Turn-Off your WINDOWS UPDATE command. Click none if you don't want to activate if at less you can enter in the desktop. As soon as you keep activate maybe next you open you cannot use it anymore then again reformat system. please do. good luck!
well i typed regedit on the run command i did all that steps and at the end it told me that it did activate windows but then like i said that when i boot up it tells me to activate windows and when i say yes it already tells me that im already activated
