First check the water inlet tap
if the water from the tap does not has moulds then your refrigerator has moulds in the water line
for this you need to dispense water regularly untill the moulds gets lesser and lesser
also observe if that mould is really a mould or something is coming off your refrigerator dispenser
could be silica from previous filter
cannot confirm unless you observe the mould.
Thanks
It look like the hose may have fallen off. Remove the panel. It might be a simple fix.
Your water line located there is broken. It's plastic tubing.
SOURCE: water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
SOURCE: Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
SOURCE: my ge fridge model TBX18k lg has water build
Remove the food from the freezer and then remove the rear freezer wall . Should be 2-4 screws and maybe a clip on each side on the top vent . Once the panel is removed , useing a hairdryer , defrost the tray below the coils until you can see the drain hole . Defrost the drain hole until water begins to flow into the hole . Use a small hose inserted into the hole and blow out any debris which has accumulated . You can also use hot water to help defrost the drain hole . Once completed , reinstaal the panel and of course , food .
SOURCE: water dispenser line leaking at bottom of freezer
if you have enough room left you can just cut out the hole and go to any hardware store and pick up a water line coupler and repair it....if it is too short or broke up inside the door then you need to remove the water/ice dispenser and pull the line through and run the new one down the track.
