Look for error Power supply must be defective, repair or replace
it. Installing a Good Spike protect on Grounded Receptacle.
Blessing.
[email protected]
cell+whatsApp:+50588611441
SOURCE: nautilus tc5000 treadclimber has e5
The E5 error code indicates the electronics on your treadmill require calibration. Recalibrate the machine per the instructions in your manual to clear this error code.
Testimonial: "Solved the problem. Thanks. Now have another one. Says "No Speed Sensor.""
SOURCE: Thanks for calibration tip.
Not necessarily, it might just be out of place. try to follow the troubleshooting guidelines in the manual. I had the same problem and my speed sensor was just out of place and not being read. Also check that all connections are connected to MCB.
SOURCE: E5-5 error code on Treadclimbe
follow the steps and fix it. God bless you
The power up test sequence has detected a key in the
operated condition. The power up test
sequence is performed every time the unit is turned on
(powered up). This test is performed
because a permanently stuck key will inhibit the
correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck
in the operated condition.
2. One of the upper PCA's keypad interface chips has
failed.
3. Liquid (perhaps perspiration) is present on the
surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper
PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the
cause. The keypad is typically part of
the display housing. Replace the display housing to
correct the problem.
2. Remove the keypad connector cable from the upper
the ERROR 5 is still
present, the upper PCA is the cause. Replace the upper PCA to correct
The
Steps for Newer Style Console Calibration:
Locate the calibration area on the
rear or underside of the console (a hole, near the console's center,
that goes through to the electronics board. (This hole should not
have a screw in it.)
Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click
when pressed).
Press the button 2 times
(with the pencil eraser). The first click should show CL11
in the console, the second click should show CL21.
If the process was done correctly,
and CL21 appears in the console, you are in "calibration
mode." The next few steps consists of pressing buttons
on the console and observing settings. This will not require
any other tools.
Press ENTER. CL22 should display
in the TIME window and (??) in the SPEED window.
Press ENTER. CL23 should display
Press ENTER. CL24 should display
Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window.
Press ENTER. CL26 should
display in the TIME window. You should then see the
letter "E."
Press ENTER. You should see "SS"
or "55" in the console.
Push the STOP/START button. For
safety, at this point, you should step off, or be off, the
treadmill.
Push the ENTER button. The walking
belt should start to move, accelerate to maximum speed, then stop on
its own.
When the belt stops, the
incline should self test by raising to its highest
incline position, then lowering back down to its lowest
position.
Once the incline test is complete,
push the POWER button 2 times. The unit should shut off and the
console should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use.
Error
5
Description
The
power up test sequence has detected a key in the operated condition.
The power up test
sequence
is performed every time the unit is turned on (powered up). This test
is performed
because
a permanently stuck key will inhibit the correct operation of the
unit.
Possible
Causes
1.
A key on the display housing is permanently stuck in the operated
condition.
2.
One of the upper PCA's keypad interface chips has failed.
3.
Liquid (perhaps perspiration) is present on the surface of a touch
sensitive display.
Possible
Remedies
1.
Remove the keypad connector cable from the upper PCA. Restart the
the
ERROR 5 is no longer present, the keypad is the cause. The keypad is
typically part of
the
display housing. Replace the display housing to correct the problem.
2.
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correct
