Technician advised that may be pcb is faulty because of water or detergents. But i think its protected by a layer of silicone & its situated on top of the machine.
SOURCE: Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
SOURCE: Kenmore HE2 #1104751. Overflows as it is just beginning to fill with water
Unfortunately - some repairs are expensive (labor wise) and not financially sound to repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: WASHING MACHINE NOT DRAINING
It appears your pump has failed or the inlet scree is plugged in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
SOURCE: just purchased daewoo washer DWD-WD1353RC..it
this washer has different detergent concentration levels settings.
1.By holding delay wash then power button at the same time, while unit is off. then a C1,C2,C3 are main detergent concentration settings C1 being regular HE detergent and C3 being very concentrated some detergents tell you X2, X3
S1,S2 are softener
B1,B2 are bleach
2. Then use buttons Delay wash to scroll for main detergent
Extra rinse for softener
Bleach for bleach
3. power button to exit and confirm
hope this helps also in manual and to clean tanks, Manual says to call a 1800# or find the instructions on the web.
I've had this washer for a week no problems yet
