SOURCE: user password is being said as incorrect to go into my laptop
you can go to dos and try to see if u can change it there.but it sounds like it got changed.if you need more help let me know
Without using 3rd party pay-for tools, I would recommend locating the Windows CD that came with the machine. I would then boot to the CD, and use the Recovery Console option. When you get into the recovery console, you should be able to log in using the administrator password only. This doesn't load the Administrator profile, it just uses the password for permissions reasons. I would then navigate to the Documents and Settings folder (assuming this is XP) and rename the Administrator profile folder to something else. Once you rename this folder, restart the computer, log in as Administrator again, and Windows will create a new profile for the Administrator, and leave your old one alone. Once you're logged in, you can browse to the old profile and get your files and pictures back.
SOURCE: Chrome Keeps redirecting my fmail
Check your windows clock time, set it to the right time or update your time with a internet time server like time.nist.gov then close chrome windows .. reopen it and voila ! good luck n hope this help
SOURCE: Error 2 (net::ERR_FAILED): Unknown error.
I had the same problem. Works fine by running Chrome with this switch
chrome -winhttp-proxy-resolver
SOURCE: google chrome apps and extensions were deleted
well the easiest thing to do is sync your browser w/your email address. if you haven't done this, there's really no way to restore it unless you do it manually. to sync google chrome to your email do this:
go to the wrench icon @ the top right.
go to options
click the 'personal stuff' tab on the left
the first option is to sync your account, follow the setup instructions.
If you have already done this, there's a button to resync all your settings. good luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
