Digital cameras come in two varieties: those that use AA-size batteries and those that are powered by proprietary lithium-ion batteries. If you are a traveler, particularly someone who enjoys remote or rustic locations, choose a camera with AA batteries.
When a camera that uses proprietary batteries runs out of power, you have no choice but to plug the battery into a power outlet to recharge it. This requires an available outlet, a battery charger, and, if you're in a foreign country, a power converter. If access to an outlet is ever in doubt, or if you don't want the hassle of carrying cords and chargers, then the limitations of this system are obvious.
When a camera that uses AA-size batteries runs out of power on a trip, you can simply throw out the old batteries and drop in a new set of high-performance AAs like the Energizer E2 Lithium line. Two or three sets of such batteries can usually take you through a 10-day trip. If you're out of high-performance batteries, you also have the option of using standard alkaline batteries, which are available anywhere in the world, and make a cheap and convenient source of backup power (though they only offer a fraction of the life of high performance batteries).
Recent trips to Asia and Africa have borne this theory out—after my companions' cameras had been sidelined by dead batteries, I was still happily shooting away with my AA-powered Canon PowerShot.
Travelers should use cameras with AA Batteries
Usually these will take two 6V 4ah sealed batteries ( about $12.00 for the pair shipped - available from a number of Ebay sellers). Pop off the back cover - verify the type batteries then replace them hooking the red and black wires terminals the way they were originally.
It might be easier to carry a spare battery. I am not familiar with your unit. I do not understand how a jump start would work without an external power source.
the batteries are gone . it carries 3 small 1.2volts battery 1 1/8" long and 3/8" in diameter soldered together making it 3.6 volts why couldnt duracel used aaa instead .couldnt find these batteries online. batteries are nickel metal hydride type 300mah.
Your problem is almost certainly a bad battery. The fact that it lights for 3 to 5 min after each recharge indicates that the charger is good, and the battery wont take or hold a charge. That is my guess. Batteries Inc stores carry these batteries and are very helpful they also have a website: www.batteries-inc.com
While it could be the battery, it could also be the internal charger in the spotlight. When you plug it in, it bypasses the charger and uses the connected power. However, it is likely just a bad battery. The batteries only last 3 years in an ideal setting and since these lights are typically only used certain times of the year, the batteries discharge and go bad. New batteries can be found at: http://batteryinternational.com/spotlight-batteries-vector-battery.html
