Sounds like it may have a cold solider joint or a loose connection on the board take the top off blow out all the dust and look for a loose connection or a burned trace on the board
It sounds like you have a intermittent problem in the driver output stage, it should be exchanged for a new one, because this is a problem that can not be fixed easily.
Are you watching 10HD off the air from an antenna? You are losing video and audio intermittently, which may just be indicative of a weak signal. Does your TV have a signal meter?
