Have tried shutting it down.
SOURCE: no boot..no power
This is another possibility, the socket where the adapter lead plugs into your computer, from the mains! this could be faulty dry jointed. Just thought it might be of help, Because the problem you had I had and this was the culprit!
SOURCE: Outlook Express malfunctioning
By changing the user name, you can download mail from any Windows Live Hotmail folder (not just the Inbox).
SOURCE: Microsoft Outlook Express compacting pop-up message
Outlook express WILL compact messages stores after every 100 closings, and WILL continue to prompt until you allow it to do so
Compact the files yourself or allow it to occur
/dbx corruption and loss of all messages WILL happen if you do not compact the database,
that is why a hotfix was issued that forces Outloook express to compact
File
Folder
Compact All Folders
Do not interupt the process
SOURCE: Application Calender Storage( process com.android.providers.calender)has
When a message like this pops up there is usually a "Force Close" button located one the pop-up, click it. This shouldn't even be happening, this is a built-in application for storing calendar events, if you don't mind not being able to use the android calendar that's fine, but if you want to use it and want to keep your warranty, take it back to your carrier's store, ask them to either swap your phone or somehow reinstall the OS so that everything works. You didn't do anything.
