Failing internal components (but first before sending in for repair, check the computer graphics card is ok, as this, or the VGA cable to monitor may be suspect) In effect what is happening is that the hardware that controls the spread of green and red pixels on the screen has failed (happens over time), this will need repair or more likely replacement
It means your PC video resolution is too high for the monitor to display, you need to set your PC video to the native resolution of this monitor, 1280 x 1024 @60Hz.
Start up in sfae mode (hit f8 while booting up), select VGA support, then right click on desk top/properties to bring up display property/setting. set the new resolution , reboot.
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
