Possibly the port you're using on the TV is bad, try another port, if still same "no signal" try different cable, also, try testing another device connected to TV without using DirecTV box, if the test device works, Call DirecTV support to report your issue with box, if the test device doesn't work the motherboard of the TV needs replaced.
SOURCE: bose cinemate no sound
Yes it will work coming straight off the dirctv box. What kind of tv do u have that doesnt have an audio out. I have had to actually use rca splitters to get sound from bluray and cable box because the new samsung led tvs only have optical out. Dont forget the unit not being used must be off or u will have 2 source sounds at one time playing.
SOURCE: I have 2 DirecTv boxs on my bar each connected to
Unless there`s a facility on the remote for A/B or Rem1/2 selection, you`re snookered I`m affraid, Back to plan "B". Ian
SOURCE: coby dvd 755 home theatre system hook to directv
The composite output (red, white and yellow) on the directv receiver should connect to the audio in (red and white) on the coby ht system. Then you have to select the correct input on the coby til you here the audio from the DTV receiver
SOURCE: I'm trying to connect my Polaroid 15
You need to do a factory reset on these tv's to get it working everytime you power it up. Then you can toggle through the inputs to get it to work. What a pain!!
SOURCE: what could be wrong if i have everything hooked up
1. Make sure it's connect to "Audio Out" on your DirecTV box.
2. Yes, the blue light should be on while unit is on an received a signal.
3. Check a second set of audio cables, just to be sure.
4. Toggle the Auto On/Off button on the ZVOX remote.
5. Make sure you've turned up the volume via the ZVOX remote.
If all these fail, contact us at zvoxaudio.com.
Tom
