Hi @Angel Sparks please watch this video. It might help you.
How to bypass google account for ZTE
This did not work on my ZTE majesty pro
Still you have frp issue ?
-Connect wi-fi, and go to “verify your account screen”, tap on “Enter email or phone” ssid field, and type there “Techeligible” and after that long tap on those texts so that “cut, copy, share, assist” appear.
Note: If “ASSIST, or Share” options are appearing there, send me message on my fb page.
If these options do not appear, then go back to “Wi-Fi” screen, tap on “add network”, and type there “techeligible” in ssid field, after that long tap and check are these “ASSIST” OR “SHARE” option appearing up there or not. Let me know
Contact me here:https://www.facebook.com/Techeligible11/
Hello I have a ZTE maj pro I see the assist in the long tap now what
SOURCE: how could i unlock my zte merit with the google account being locked?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: Need help to fix camera not connecting on my zte
Mine does the same thing every now and then. I end up restarting my phone and it works fine after that!
SOURCE: How do I send a picture using MMS mode on my zte
This is just like sending a regular SMS. But if you want to be sure they get the picture, assuming that you are on Android, open Gallery and search for the picture that you want to send, look for the share icon, it's usually in the top right corner, tap it, from the drop down choose the app that you use or want to use to send the picture.
SOURCE: How can I root ZTE majesty window 7 android?
Its running android 4.1.2 which is Jelly Bean and is hard to crack, you could give Towelroot by geohot a shot usually works for a lot of devices.
