Not spinning in washing cycle or spin drying
SOURCE: Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
SOURCE: hoover washing machine 550mb keep
Hi are the clothes tangled up around the agitator if so the gearbox may be faulty or the brake may be worn,is it washing in both directions
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
