My other 282 has option to delete
Hi david.
go to this link and you might find the manual for this,it might be the first one on the page.
not sure if this will help you out.
how to delete calls on my alcatel one touch 282 phone Google Search
SOURCE: Deleting files from HTC Touch Diamond
GO TO FILE EXPLORER > MY DOCUMENTS> MY VIDEO
TAP ON THE FILE AND HOLD YOU FILE OPTIONS, THEN YOU DELETE FILE
SOURCE: delete divert on disply
use ##002# to cancell all divert. This will work only in GSM networks.
SOURCE: delete messages alcatel 282
go to messages.. and press the more button go down to either delete all or select all after you select all then press delete. hope this helps!
SOURCE: hw to get network key to unlock alcatel 282
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
