Question about Toshiba Tablets & eReaders
My 8 inch toshiba tablet is stuck on the password screen and instead of the keyboard popping up the google voice pops up and the the google voice is also sruck how can i fix this please help?????
    Top Expert:
  • Toshiba Master
  • 8,546 Answers
Hi glen.
go to this link and scroll down the page you might find something that might help you out.
8 inch toshiba tablet is stuck on the password screen Google Search
Posted on Nov 02, 2017
6ya staff
SOURCE:
vijay
Vijay Damaraju
  • 27 Answers
SOURCE: Viewsonic Tablet PC keyboard issue.
may be the best solution for this problem is consult your hardware manufacturer and ask him to replace the motherboard, if the pc is under warranty they will replace it for free of cost.
Posted on Apr 06, 2007
Anonymous
  • 61 Answers
SOURCE: problem .......x61 tablet help !!!!!!!
Hello snapshots,
I have an x61, and you may want to check that all of the keys on your keyboard are not damaged, and that none of them are stuck in the pressed position. That is what the "stuck key" message typically means. If you check out the keyboard, and all the keys are fine, and if you are still receiving this message, try calling Lenovo support. There is an off chance that your keyboard (or other components) may be slightly defective.
Here is the link to the Lenovo site: http://lenovo.com/planetwide/select/selector.html
Hope this helps!
Jeff
Posted on Mar 13, 2009
Anonymous
  • 154 Answers
SOURCE: Password problems on a Toshiba Protege m200 laptop
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password.
  1. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
  2. On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
  3. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
  4. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
Good luck and more power
nicole
Posted on Oct 03, 2009
hrr1117
  • 111 Answers
SOURCE: remove password bios toshiba portege m400 please!
Here is a guide toremove windows passwordwith Windows Password Recovery Tool Professional from http://www.windowspasswordsrecovery.com/Step1: Download and install Windows Password Recovery Tool.
Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn a Windows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4:Remove the forgotten Windows passwordwith the burned CD/DVD/USB. Then log on to Windows without a password.
Of course, you can also finish Windows password remover if you have a password reset disk in advance. That's also an easy solution.
Source: http://www.windowspasswordsrecovery.com/windows-password-remover.htm
Posted on Aug 20, 2012
Jim Dowell
  • 345 Answers
SOURCE: have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
Posted on Dec 20, 2012
I have iNew V8 MTK phone. I do not have my keyboard ASOP on the phone. How can I get this feature back?
The Motorola website says to try this:
Back to Previous Page
Why am I missing the Android Keyboard (AOSP) option?
If you are missing the Android Keyboard (AOSP) option please try the following:
  1. From the home screen touch Menu
  2. Touch Manage Apps
  3. Touch Menu
  4. Touch Reset app preferences recovered
Was this answer helpful?
Aug 30, 2016 | Tablets & eReaders
P1000 10.1 polaroid tablet. How can I get keyboard to work?
Hi they r cheep to buy on E/BAY APROX $23. THIS WOULD B THE BEST WAY TO FIND OUT IF IT IS THE KEYBOARD OR YOURE TABET THAT IS AT FAULT CHEERS
Mar 07, 2016 | Polaroid Tablets & eReaders
My daughters home page on her irulu 7 inch tablets is typing by its self. How do I stop it so she can enter her password
Hard Reset the tablet by holding the power on off whilst holding the volume down button until machine switches off, then restart.on some machines it may be volume up instead, others it will be the home button and power button.this should reset tablet to default settings.If it continues to play up then it is likely the touch digitizer is faulty.if you are trying to use a USB keyboard disconnect it before doing any of the above then once tablet is running reconnect the device.it could be the USB keyboard that has a key stuck down due to spilt drink or food.hope this gives you some pointers.
Jan 24, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
How do i get my nextbook tablet to switch from voice input to keyboard?
Go to Settings, Input and you should see options for turning off voice input, and also for selecting a keyboard (if more than one option is included).
Jul 18, 2014 | Nextbook Premium 7 Capacitive Touch...
Cant download games from play store
please describe the issue. Is it not downloading the apps like the download bar is getting stuck or do you get an error message. Please be as descriptive as possible.
Mar 25, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
Zeepad tablet instructions
Touching the input field 'box' doesn't open the keyboard?
Feb 06, 2014 | Tablets & eReaders
I want to add a password to my Irulu tablet (Android os 4.0). How do you do that. I went to settings + security but found nothing.
Instead of going to Security you should go into the lock screen options in there you can select a PIN or password
Oct 21, 2013 | Irulu 7" 4gb Mid Google Android 2.3...
Emerson tablet
Hold the power button down for about 8 seconds to force it off. Hold it till screen goes dark. Don't release if "power Off" dialogue pops up. Keep holding it to force off.
Apr 16, 2013 | Tablets & eReaders
Tablets & eReaders Logo
44 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Ekse
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
