SOURCE: frigidaire washing machine
OK Check elec plug at motor . Mine was doing exac same thing . Take belt access panel off back and pull wire plug off motor and push back firmly on . This plug does not have a tab so vibrates off . Good luck .
SOURCE: Washer starts then stops how do you reset the washer
Try turning off the circuit breaker for 60 seconds and turning back on again. Then turn on washer.
SOURCE: What does
You press the two buttons on either side of the lock icon for about 15 seconds and it clears it.
SOURCE: Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
SOURCE: err code e47 frigidaire front load washer
E47, no spin.
Replace the door lock.
To learn more about your washing machine, or to order parts, click here.
Related Posts:
Thank you for your inquiry, Dario Hernandez!
I see that you are having difficulty with your Frigidaire front load washer displaying an "ERR" code. Typically "ERR" stands for an error has been detected this could mean that you have a miscommunication within the control panel. I would suggest resetting your washer and you can do that by flipping the household circuit breaker off for roughly ten minutes. If you continue to have an issue with your washer I would recommend contacting a professional technician for a diagnosis to be completed. The technician will have the appropriate tools to pinpoint the part needed for repairs. Hope this is helpful information. -OOS
