Standard default passwords are 1234 or 0000 or 9999 or 2249 try those first. Otherwise you can also try 999999 000000 123456 if you can enter 6 digits. Also try "Reset All" on some models that does not require a PIN. if all else fails Westinghouse support should with it.
Customer Service Request WE
SOURCE: need 4 digit password for rca tv 2003
Most RCA and GE TV sets use a four digit code to control the v-chip.
The code reset procedure is different depending on the model. Try each
method until you find one that works:
Depending
on the model, one of the methods should unlock the V-chip. Now, if
desired, you can change the settings on the V-chip by going to the MENU
and going to PARENTAL CONTROLS, or on some sets, going to MENU and then
going to TV SETUP, then to V-CHIP SET.
go to www.fitness.manualsonline.com or www.remotecodelist.com
God bless you
SOURCE: Access code for westinghouse tv model LD-2240 serial 6616121307447
You're asking about its service mode code I assumes, and posts this solution. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now
