Does side port allow for a power cable?
SOURCE: Sharp + VL-Z7 + Software
Please go to: http://www.sharp-cart.com/ecom/accessories.htm?action=getSearchItems&ss_id=979&view=catalog/ss_items they have the CD-ROM for $ 11.00. Good luck
SOURCE: I HAVE a sharp viewcam vl-h860 hi8
If you're pretty sure the camera is just dead and have already resigned yourself to buying a new one you could just pry the door off and get your wedding tape out. There are lots of places that can transfer it to VHS or DVD for a small fee. On another note, I have a camera just like it, have lost the AV cable and can't seem to find a replacement online. Care to sell me yours? If so send me an email at [email protected]. Thanks!
Staci
SOURCE: Replacement charger for Sharp Viewcam VL-Z3
As long as you can obtain a charger that is rated the same as the one for your camera it will not be a problem unless the original charger is a microprocessor controlled charger that has the ability to control and change the charging current as the battery charges.
A camera shop can check this out for you.
If it just a simple AC or DC charger, then you can simply use the connector from your original charger and join it either by soldering or with a screw terminal block(which you wrap in Insulating tape once fitted).
The main thing you need to be CERTAIN of is as to whether the original charger is an AC or a DC type.
This will be clearly indicated on the label on the charger.
Testimonial: "thank you for the answer. Bill"
