When I press the side button on the space saver ice system as directed, I am not able to lift and remove the ice storage caddie
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
SOURCE: KENMORE COLD SPOT REFRIGATOR/FREEZER,MODEL 106
hi thanks for the question if the ice cubes are formed in the tray nicely then you need a new ice maker if the whole ice tray is a smooth sheet of ice the freezer might not be cold enough empty out the ice manually ant try again &lower the freezer temp thanke the appliance doc
SOURCE: Ice maker won't make ice after emptying ice bin manually.
make sure you push the ice lever back down
SOURCE: GE Monogram refrigerator ZFSB26DRE - ice bin stuck
their has to be a release botton on it look around inside
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
