SOURCE: My microwave shows a H98
That would be a Panasonic inverter failure code, but please reply back with your brand and full model number.
SOURCE: MESSAGE DISPLAY H98
The H98 fault on a Panasonic can be a bad magnetron, inverter or control panel.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Panasonic Microwave
the error code H98 refers to the heating filament on the magnetron, unless you are confident I would not progress further
SOURCE: Panasonic Microwave show H98 in window
H95, H97, H98 or
H99 mean that there's a problem with your inverter,
magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of those
components has failed.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
SOURCE: Error Code
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
