Upon pressing "Start", The water is entering the machine, then the pump starts its work and takes out the water and the machine stops. the drum can move freely manually , but no noise from the motor.
SOURCE: LG WM1812CW PROBLEM
Just had this same problem on my LG wm1832CW machine. Sensor assembly was replaced and all is well..
Simple and fairly inexpensive to replace.
SOURCE: washing machine drum won't turn under power
is the washing machine went to its usual cycle? put water in?
if you think the motor should have run already, then it could be the motor or the motor inverter.
check the motor leads for equal resistance, if i'm right, you may have a three phase motro so the three leads that comes out should have equal resistance.
also, if you can monitor the voltage present in the motor leads while it is plug in and you are waiting for the motor to run, if there is voltage then there is a problem with the motor, if there is no voltage present, then the inverter unit would be the defective part.
tnx 4 using fixya,
drcool
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
SOURCE: Numark TT1 need to be manually started by moving platter
that'll be a blown component of some sort on your main board i think mate,youll wanna get some one handy wiyh a multi meter.gd luck
SOURCE: fault code f12
communication error .Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wiring Harness connections to the MCU, the motor, and the Central Control Unit (CCU)
• Check the Drive system
• Check MCU
• Check CCU
• Check Motor
Replace failed part
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Hi
Intake/Drain light flashing means an issue while
draining. You would need to check for air gap on the dishwasher, it may be
clogged. It prevents dishwasher from draining, sometimes the drain flow is
restricted due to gunk. Cleaning or bypassing the air gap will resolve the
issue. If this doesn't resolve the issue then it is due to seized (or stuck)
drain pump. Disconnect the power to the dishwasher or turn off the breaker to
the dishwasher. Tip machine on its back; remove screws that hold the bottom tray
on. Remove the hoses to the main motor, remove electrical connections &
remove motor (single screw holds motor, it is on the outside back of the
machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate
it, then motor will be required. If the error still appears then cancel the
error message, turn the rotary selector switch to "Stop/End" or press
the "Start/Stop" switch for approx. 5 secs. Switch the appliance off
and then back on again. Hope this helps... Please post back if you need more
information.
Daniel
Hi
information.
Daniel
