Watches Logo
R
Robin Kumataka Posted on Nov 06, 2017
Just bought an Anne Klein watch Ak1855mptt, cannot get to start
5 Related Answers
Anonymous
  • Posted on Dec 09, 2009
SOURCE: anne klein watch battery replacement
My Anne Klein uses an EverReady #377. The internal time module from Hong Kong is stamped with "AL21E."
I hope this helps you.
Anonymous
  • 98 Answers
  • Posted on Jan 10, 2010
SOURCE: How do I remove links from an Anne Klein watch
Many watch companies are including extra clasps on the bands so customers can adjust the band easier on their own. Check the bottom of the band for those.
If not I suggest going to a reputable watch repair shop and have them do the adjustment for you. It will save you time and frustration of trying to do it yourself. If a screw or pin drops and you cant find it you may end up having to reorder them from Anne Klein!
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 20, 2010
SOURCE: where can i purchase 3 extra links for my Anne
Click on my profile, then click on TIPS AND TRICKS, There you will find a phone number for ordering parts from AK. Rate me, plz.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 15, 2010
SOURCE: I have an Anne Klein watch and have lost the clasp
Call the following number between 8am and 5pm EST: 1-800-937-0050 ext. 203. You can order watch bands and parts there.
radar001
Bob Korsu
  • 1051 Answers
  • Posted on Aug 05, 2010
SOURCE: how do i take the
If it's a pop-off type back, (you can tell by running your finger nail around the edge between the back and the case) If you find a slight indent or flat spot near the 12 o'clock position it is a pop-off back. Use a very sharp blade and VERY gently pry the case back up at this spot. It should pop off easily. Don't force it or it'll bend. To replace: line it up in the same position it had been and apply firm pressure untill it snaps back. If it's a screw off back (it has a series of slots around the edge) you'll need a case back tool to remove it. In that case it'll be easier to go to a jeweler.
Testimonial: "very good"
How to adjust Time and Date on Anne Klein 10/7899 6P05 Ladies Watch
You need to pull the crown out 2 clicks and rotate to set time.
1 click and rotate for day/date functions.
Push in fully to lock settings and resume time keeping.
Nordstrom provides a generic Anne Klein manual here:
http://i.nordstromimage.com/images/default/shop/image/misc/watch-manuals/anne-klein/anne-klein.pdf
How do I set the date on an Anne Klein watch with only a stem?????
-GB&q=anne+klein+watches+how+to+ http://i.nordstromimage.com/images/.../watch-manuals/anne-klein/anne-klein.pdf .
Hello, you can download a pdf instruction sheet at the above site. Hope it helps. Bye.......
1helpful
Need extenderfor Anne Klein watch model 10/8031 SVGY.
I would recommend going to a watch repair shop for this. Depending on the style of bracelet there are a couple solutions. I would suggest a shop familiar with or that carries Anne Klein.
Most repair shops will have extender links and clasps. If you have a fashion watch that doesn't have a typical clasp or bracelet set up a Anne Klein dealer will be able to better assist you in getting a solution from Anne Klein.
Precision Time has Anne Klein and they do a fair job of getting parts through their repair center. You can visit their web site at PrecisionTimeCo.Com.
Sep 22, 2009 • Watches
The crystal on my Anne Klein watch needs relacing. I took it to a jewler to have it replaced, but they told me I'd have to order it from Anne Klein and they ( my jewler) would put it in.
This is right. Anne Klein do not supply any parts to customers, so, you have to ask your jeweller/watchmaker to order the glass first and then they gonna fit it.
You have another way to do that; ask your jeweller to send your watch to Anne Klein, where the glass will be replaced, but this way it will cost a lot more and you will have to wait much longer.
I'd advice to choose the first way, as there is no difference where the watch glass was fitted.
Rate me, please.
130helpful
5answers
Need extra link for an Anne Klein 10-7977MPTT watch
Yes you can, go to amazon and take a look: Amazon com Anne Klein10 7977MPTT watch link. Wish you best of luck.
Cheers
Top Anne Klein Watches Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Anne Klein Watch Expert? Answer questions, earn points and help others
