I only want to know if the SIM card will work as we already have it and we want to stay with Vodafone
Hi if the Telstra phone is unlocked it will work.. cheer's
Testimonial: "What if it’s locked"
SOURCE: my nokia 5300 handset not working in all sim card
this phone might have been made only to detect the airtel sim cards as the phone in question might have been made only for the air tel company
in collaboration with nokia .
so there might be no code for it to allow all the sim cards .
imagine it like the cdma phone distributed by reliance communications
SOURCE: sim card rejected !!!! nokia 5300 xpressmusic phone
ussually rejected simcards. are really unable to use. nor you really cant use that at all. instead buy a new one. if u entered a wrong pin thrice. then the sim card will asks you for the PUK code. which youll see it tipically from the card where you tore off the sim. or from the paper wer insertd @ sim package..
SOURCE: my sim card doesnt work in my sciphone i68+
I see that this had been a while. The reason that your Sim cad doesn't work could be various: 1. Make sure that your phone is quad band, if it's a tri band then make sure that ATT works in 1900mhz. If it works only in 850 and your i68+ is a tri band, (which is not suppose to) then it will never work. As far as I know all i68+ original are quad band, some fakes i68+ are sold as quad band but are actually tri-band. 2. If you ATT sim card is a 3g card, it won't work either. These phones are not yet equip to work with 3g. I hope this clear up at least a little of your doubt with the Sciphone.
SOURCE: blocked sim card vodafone. No pin code
PIN CODE:
HI
If you are asking for pin contact your service provider , he will give
you a default pin .
If
you try pin more than few predefined no of times your phone will ask
PUK code which can also be given only by your service provider which is
specific for each and every mobile number . Do not try PUK(new pin code)
code many times or else your sim will be blocked and you will need a
new sim.
Contact your sim
customer care department over phone. Its free of cost to get the
pin or puk no.
Go to the nearest service
outlet of your service provider they can also help you.
There
is no other go than the above procedure only your service provider can
give it nobody else in this world nor any software.
Testimonial: "Thanx,pretty much thought that was the case"
