My truck no click no start ? GPS?
SOURCE: mitsubishi montero sport 99 - car will not start.
could be your ignition switch, first make sure you have power going from your battery to the starter, check at the starter for 12.5 volts then make sure starter has its ground, if that isnt it test the ignition cause thats probably what it is.
SOURCE: Replace Spark Plugs on a Mitsubishi Montero Sport 2001
http://www.autozone.com/autozone/repairinfo/common/repairInfoMain.jsp?targetPage=productsHowToInspect&leftNavPage=productsHowTo&pageId=%090900c15280213e6e&subtitle=service
Try to copy and paste this web site. It's for Auto Zone. It will tell you all you need to know about your vehicle.
Good Luck and hope this helps.
SOURCE: Changing transmission filter on Mitsubishi
FIRST YOU HAVE TO UNBOLT THE TRANSMISSION PAN ON THE BOTTOM OF THE TRANSMISSION. THERE WILL BE FLUID IN IT SO BE CAREFUL NO TO SPILL IT. AFTER THE PAN IS OFF YOU WILL SEE THE FILTER ON THE BOTTOM OF THE VALVE BODY. IT MAY BE BOLTED ON AS WELL. HOPE THIS HELPS. LET ME KNOW. GOOD LUCK
SOURCE: mitsubishi horn doesn't work
in my 98 montero sport the horn relay is next to the power steering resivour. As you look at the engine far left side a little black square. Just changed mine cause it went out
SOURCE: Find starter on 2000 Mitsubishi Montero Sport
I have a 98 Montero Sport and the starter is located on the bottom left side of the engine. Its a very tight spot but I unscrewed a bracket in which 2 transmission lines were running under the starter and it gave me more room to play with. Ensure to disconnect battery before you begin
