SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
SOURCE: Freezer just not getting cold enough
The defrost heater element is bad, Do you know enough engineering to tackle the job ? You will need some hand tools and a spare Saturday afternoon .. Alternaively you could call a technician...
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
Try Cheyenne Lamps 2000 E. 17th Street Little Rock AR
501-374-2829
SOURCE: I have a Hunter model 21241 ceiling fan with
The ballast is still available on the internet, just Google "veb82122." They want $37 plus shipping. You can also but a 22W Circiline ballast at Home Depot that will work for about $18. (Lowes does not carry them). The original ballast is a solid state design, light weight and instant on. The Home Depot ballast is the heavy transformer kind and a real pain to modify the bracket to make it fit. I have 8 of these Hunter fans and I have installed the Home Depot ballast on two if them so far, but I think that I will order the solid state version as a spare for the next time.
SOURCE: I have a hunter ceiling fan. The motor works fine,
NO YOU DO NOT !! there is a little black box on inside of fan that controls the lights, its a ( watt governor ). just remove this black box and wire directly to the lights. problem should be fixed !! have a good day !! this is another goverment quick fix.
