Optics Logo
j
james Pierce Posted on Nov 08, 2017
I have a zeiss conquest 6.5-20x50. The elevation turrets have two full rotations. The reticle won't move or down
5 Related Answers
Anonymous
  • 6982 Answers
  • Posted on Jun 19, 2009
SOURCE: New Zeiss 2.5-8 Conquest MC Riflescope. Elevation clickstop adjus
Tried google for zeiss rifle scopes I just did and see they have a suport division...try there and get it from the horsies mouth!!!
Anonymous
  • 5 Answers
  • Posted on Sep 14, 2009
SOURCE: what is the procedure for sighting a zeiss z-plex
mount it, get a 100 yard target, and you have to chase the bullet right is left up is down
Anonymous
  • Posted on Oct 16, 2009
SOURCE: Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
Anonymous
  • 2702 Answers
  • Posted on Sep 06, 2010
SOURCE: Elevation turret stripped out. Entire turrent
ok,,,you have strong fingers then????
try a drop of supper glue on the striped out turret thred,,,as the scope is a right off anyhow you have nothing to loose do you?
Anonymous
  • 3 Answers
  • Posted on Dec 27, 2012
SOURCE: Adjustment Issue
up/down is on top. left/right on the side...
Zeiss conquest parallax knob slips
Zeiss has a lifetime warranty on their conquest line. Contact Carl Zeiss Welcome ZEISS United States
Hi I sighted inmy rifle today with a Ziess Conquest scope. When i needed to bring the point if impact up . The impact moved down instead. I turned the scope turret to the right like the markings on the...
I hate those 'direction' arrows. I usually end up ignoring the arrows and moving it however it takes to get what I want.
Raising the crosshairs will cause you to have to point lower to make the round hit on target.
2answers
I shot my new 4.5x14x44mm conquest scope and tried to adjust the cross hairs according to my shots fired but the shots kept hitting in the same spot after a box of shells. i had it bore sited and i still...
Is the country of origin China.. Sounds like the reticle is stuck,, like from being dropped maybe in shipping. OK, Without any adjustments made shoot it one time, if you tap on the side of the scope, not the top of the turrets with a plastic/rubber hammer and point of impact changes (jumps) its faulty.. you cant fix it.
Dont understand why on top of an side of scope setting there is ur ur instead of left right or up down
The "U" indicates Up on the elevation dial, and the "R" indicates Right on the windage dial. Turn the elevation dial clockwise to move the point of impact up, counterclockwise moves down. Similarly, turning the windage dial clockwise moves Right, and counterclockwise moves left. Here's a scan from the Zeiss Conquest manual:
Is the Zeiss conquest Z-plex scopes first or second focal plane?
Zeiss Conquest scopes are all second focal plane scopes. This indicates that the reticle, Z-plex in this case, is located on the second image plane.
  • Reticles on the second focal plane remain the same size regardless of the magnification setting of the scope.
  • When on the first focal plane, reticles will increase or decrease in size as the magnification is changed.
2answers
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
1helpful
What is the procedure for sighting a zeiss z-plex reticle scope?
1helpful
Top Zeiss Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Zeiss Optic Expert? Answer questions, earn points and help others
