Start button beeps rapidly three times. When i try the dial to change the cycle, the corresponding settings change (temp, dry level, etc...) but the minutes displayed on the dial dont change. Have tried cutting the power to reset, but it doesnt work.
SOURCE: Dry cycle
Try setting the washer dial to the stop setting at the end of setting number 4 then set the dryer timer and turn on the machine. This works for mine to get the dryer to run by itself. It should begin about 30 seconds later, when the door locks. Hope this helps.
SOURCE: Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
SOURCE: dryer wont start
Commonproblems...blown house fuse, broken belt ( on some models
)...door switch...*thermal fuse open (venting needs attention
)...broken or burnt wire....timer....motor, in order from mostcommon to
least common. * If you find a blown thermal fuse, always clean, change,
adjust the ventingsystem and vent hood first, then it is often a good
idea to replace the operatingthermostat at the same time. This is a picture of some modernthermal fuses.
I hope this will solve your issue.
Good Luck
If my solution proves useful please accept it.
Regards
Arjun
SOURCE: my blanco bfdw6x dishwasher has the folowing
Ours does the exact same thing. We pull it out and tip it which drains some water on the floor and then it works. It is something a technician told us ages ago, something to do with a water level switch underneath.....but its driving us mad. We have to do it on a regular basis. Does anyone know how this can be fixed more permanently. thanks.
SOURCE: Cycle buttons work, option buttons dont, Cant deselect heated dry, Wont start
I had the same symptoms and the front panel was the fix
the part with the buttons on it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
